Lanopy
Aug 07, 2011Follower
WNDAP350 - deauthenticated due to local deauth request
I have a WNDAP350 AP configed with WPA2-PSK. I am averaging about 40 clients in a high usage environment and and am experiencing random disconnects. I have both radios configured and the N network s...
RandolphBell
Oct 01, 2013Aspirant
This is clearly a memory leak in the current firmware. No matter what setting you use if you are streaming a considerable amount of bandwidth the system will eventually provide the following error messages
Sep 30 19:53:11 hostapd: wifi0vap0: STA bc:c6:db:1b:26:xx IEEE 802.11: disassociated
Sep 30 19:53:12 hostapd: wifi0vap0: STA bc:c6:db:1b:26:xx IEEE 802.11: associated
Sep 30 19:53:15 hostapd: wifi0vap0: STA bc:c6:db:1b:26:xx IEEE 802.11: deauthenticated due to local deauth request
Sep 30 19:53:15 hostapd: wifi0vap0: STA bc:c6:db:1b:26:xx IEEE 802.11: disassociated
I've modified a number of settings to provide a somewhat reasonable configuration. I say somewhat in that I'm basing "working" on streaming an HD Netflix video and despite encountering this error message repeatedly the buffer in Netflix is able to mask the error. The configuration I settled on is
as follows
Channel / Freequency - Auto
MCS Index / Data Rate - Best
Channel Width - 40mhz
Guard Interval - long 800ns
Output Power - Full
I challenge Netgear to respond to or resolve this issue.
-Randy
as follows
Output Power - Full
-Randy
