baba100
Jan 10, 2011Aspirant
WNDAP350 - serial number
Hi all, Is it possible to update the WNDAP350 AP firmware so we can find the serial number? Sincerely
SminkyMinky
Jan 12, 2014Novice
I was searching for the serial number for precisely the same user when I came across this post.
My AP's are fixed to the wall on a remote site so as you can imagine, retreiving the serial numbers to download firmware files would be a challenge.
However with a little fiddling I found that if you use the Web Client to confiure a WNDAP350 then find and switch on Telnet Remote Console (you find that under the Maintenance tab) you can then use a Telnet console to view the current configuration. Then key 'show system' to find the serial number.
I expect that this information is far too late to help benjacobs however if other people who are searching for a solution to this come across this post then I hope this saves them the hassle of removing the AP's as it did me.
