Geforce
May 09, 2013Novice
WNDAP350 & 2 x ANT2407
Hi, I've set up and purchased 1 x WNDAP350 and 2 x ANT2407 Antenna's but with poor results it seems. I've enabled external antennas in the 2.4Ghz range, but it doesn't seem to make an awful lot ...
Geforce
May 11, 2013Novice
jmizoguchi wrote: I use open-mesh OM2P and 24db/ 400mW
I have three of in my house and it broadcast too much... :)
7db antenna is probably not difference then internal one
http://www.downloads.netgear.com/files/wndap350_ds_11nov09.pdf
Adjustable transmit power control (TPC) from 100 mW down to 0 mW
Not much
hi, thanks for replying.
I'm not sure I quite understand - I don't know what open-mesh OM2P means or the relation to 24db/400mW.
I thought the WNDAP350 has an internal 5dbi antenna, so therefore the 7dbi antenna is better and more range?
I'm really struggling with this one. My boss has a big house and I'm trying to give wifi converage from one access point using omnidirectional antenna's.
Any advice??
