Geforce
May 09, 2013Novice
WNDAP350 & 2 x ANT2407
Hi, I've set up and purchased 1 x WNDAP350 and 2 x ANT2407 Antenna's but with poor results it seems. I've enabled external antennas in the 2.4Ghz range, but it doesn't seem to make an awful lot ...
jmizoguchi
May 11, 2013Virtuoso
I use 3 and puts out 26db on each right now. Antenna is 2db so unit will put 24db.
It's better than anything.
Products is made for hotspot as well and used by MANY hotels. I just installed for contact work too.
And manage via cloud easily.
