Geforce
May 09, 2013Novice
WNDAP350 & 2 x ANT2407
Hi, I've set up and purchased 1 x WNDAP350 and 2 x ANT2407 Antenna's but with poor results it seems. I've enabled external antennas in the 2.4Ghz range, but it doesn't seem to make an awful lot ...
Geforce
May 11, 2013Novice
RRRRrrrrrrrrrrrr.. Ok I think I understand thank you.
There's a difference between the power output and the antenna db I think then.
After a quick Google, they seem easy to configure. Maybe I'll buy 2-3 to try in the first instance.
So no Netgear product is as good? ^^
hehe
hehe
