Geforce
May 09, 2013Novice
WNDAP350 & 2 x ANT2407
Hi, I've set up and purchased 1 x WNDAP350 and 2 x ANT2407 Antenna's but with poor results it seems. I've enabled external antennas in the 2.4Ghz range, but it doesn't seem to make an awful lot ...
jmizoguchi
May 16, 2013Virtuoso
You probably need to email open mesh support. They will answer quite quick
They do make dual band AP I use OM2P 26db version
All channel are automatically done by the cloud
So ask detail question to support
