DataSwift
Apr 15, 2010Follower
WNDAP350 2.4GHz drops out every few seconds
As the subject states, we've just bought a number of WNDAP350 access points. The wireless functions perfectly on the 5GHz band, but the 2.4GHz continually drops out. I'm trying to borrow a laptop with...
neog8r
Aug 31, 2011Aspirant
WNDAP350 UNRELIABLE as of firmware version 2.0.27 (August, 31 2011).
We are having ongoing problems with the WNDAP350. The 5GHz band goes deaf at random intervals and does not recover. All devices on the network must be manually reconnected to the WNDAP350 to continue functioning. When the AP goes deaf, not even the WNDAP350 can be accessed via wireless. Using hard-wire to connect while deaf enables access to the monitoring features which show nothing suspicious. We have downgraded to older Netgear AP's and verified everything with the network functions correctly. No other competing signals from other AP's.
Netgear Support has had us try three versions of the firmware (including a beta), latest being firmware being 2.0.27 and the reliability problems persist and had us try different channel settings. No resolution found yet as of August 31, 2011.
Any input on this issue would be appreciated.
"Netgear WNDAP350 Problems", "Netgear WNDAP350 Firmware", "Netgear WNDAP350 Help", "Netgear WNDAP350 Review"
