DataSwift
Apr 15, 2010Follower
WNDAP350 2.4GHz drops out every few seconds
As the subject states, we've just bought a number of WNDAP350 access points. The wireless functions perfectly on the 5GHz band, but the 2.4GHz continually drops out. I'm trying to borrow a laptop with...
RossACNS
Aug 15, 2012Aspirant
For anyone having problems with the WNDAP350 and specially with apple products like the iphone.
Enabling the WMM will help increase speed.
Disabling the Powersave will help remove some random disconnects.
Disabling the AMPDU will assure that the iPhone always quickly connects.
Enabling the RIFS will speed up the transfer rate dramatically.
Hope this helps
Here's location of changes.
Change #1
Tab=Configuration--> TopMenu=Wireless --> SideMenu=Basic ==>
QoS Setting ==>Tab: 802.11b/bh/ng & Tab: 802.11a/na
CLICK
Radio Button=Enable (WMM) {Enable}
Radio Button=WMM Powersave {Disable}
Change #2
Tab=Configuration--> TopMenu=Wireless --> SideMenu=Advanced ==>
Wireless Settings ==>Tab: 802.11b/bh/ng & Tab: 802.11a/na
CLICK
Radio Button=AMPDU {Disable}
Radio Button=RIFS {Enable}
Hope this helps
Change #1
CLICK
Change #2
CLICK
