tonymurillo45
Dec 26, 2011Aspirant
WNDAP350 disconnects frequently
Hi guys, On my company we have two WNDAP350 AP's and we have an issue, we are using MC9090 Symbol handhelds and sometimes the device loose conectivity, I know that is something wrong with the Netge...
csm746
Dec 26, 2011Novice
I did notice more stability when I flashed my 350s with the firmware upgrade 2.1.2. I use primarily N machines on both radios. There is a b/g selection if it would provide more stability than the g/n. And I have encountered some problems in the past if the access point was set to wide-channel (40 ghz) instead of 20 ghz.
I don't know if you can run WEP with these devices, but I am enjoying pretty good service with this device now.....
