tonymurillo45's avatar
Dec 26, 2011
WNDAP350 disconnects frequently
Hi guys,
On my company we have two WNDAP350 AP's and we have an issue, we are using MC9090 Symbol handhelds and sometimes the device loose conectivity, I know that is something wrong with the Netgear AP's because I have another linksys and it works great. We bought the Netgear to make a stronger wireless range, but I think right now linksys is working better than Netgear. Do I have to configure something? I already have disabled WMM and Power saving mode, it helps a little but the problem still.
Any help would be appreciated.
Thank you
  • Hi, yep I'm running the latest firmaware version: 2.1.2. My problem is that something my symbol loose conectivity. I made a ping XXX.XXX.XXX.XXX -t and I made 300 pings and at least 1% is lost.
    Thank you
  • WMS?
    sorry. I got lost with other thread
    disregard on symbols.. it was other thread..
    what is the wifi adapter model if this pc.
    Thank you
    I'm lost in my mind.. it was rich thread..
    If I where you I would get legacy wireless G and test out.
    some of the legacy wireless G devices will have hard time working with N Access point and routers
    if B&G will have an issues with it then I would get different wireless G router to compare the issues
