csm746
Dec 05, 2011Novice
WNDAP350 New Firmware 2.1.2
Having experienced some low wireless connection speeds and what appeared to be drops in wireless broadcasts, I flashed 2.1.2 about an hour ago on the WNDAP350 I run here at home to cover my second flo...
JimiSweden
Dec 22, 2011Aspirant
WNDAP350 Bandwith test using firmware 2.1.2
Note: TKIP is mutch faster than AES, I have tested on several APs (WNDAP350 that is)
Bandwith tester is iperf running against 3 servers on 2 different distribuition switches
Access switches are 100Mbit HP Procurve switches.
Summary:
the following speeds were measured on FW 2.0.9 and are a summary on 5 APs connected to 100Mbit and 1Gigabit HP switches.
3-4Mbit/s using AES
14-18Mbit/s using TKIP
From the tests on FW 2.1.2 I cannot say it is faster than previous firmware.
A test with the firmware 2.1.2 directly attached to the core layer (Gigabit HP Procurve) gave the following resluts.
(I also tested it connected to a D-link 100Mbit POE-switch with the same results)
:::::::::::::::::: NEW TEST 2011-12-22 - 16:55:53,06 :::: Location - Connected to CoreSwitch ::::::::::::::::::
Testing Server1 from: via MLMAP4 direktkopplad till POE-Switch
Client connecting to Server1, TCP port 5001
TCP window size: 8.00 KByte (default)
[328] local 192.168.1.132 port 58291 connected with 192.168.1.10 port 5001
[ ID] Interval Transfer Bandwidth
[328] 0.0-10.0 sec 22.6 MBytes 19.0 Mbits/sec
Testing Server2 from: via MLMAP4 direktkopplad till POE-Switch
Client connecting to Server2, TCP port 5001
[328] local 192.168.1.132 port 58297 connected with 192.168.1.20 port 5001
[328] 0.0-10.0 sec 22.3 MBytes 18.7 Mbits/sec
Testing Server3 from: via MLMAP4 direktkopplad till POE-Switch
Client connecting to Server3, TCP port 5001
[328] local 192.168.1.132 port 58298 connected with 192.168.1.30 port 5001
[328] 0.0-10.0 sec 22.9 MBytes 19.2 Mbits/sec
I will wait for the the users on this AP to complain or not and might do an upgrade in the end of January on the other ones if there is no complaints.
// JimiSweden
Summary:
3-4Mbit/s using AES
// JimiSweden
