RSchwein
Mar 21, 2011Aspirant
WNDAP350's are constantly rebooting
WNDAP350 significant problems I have 5 of these on various network segments over a large geographical area. All are using different wiring, different network switches, nothing in common with any o...
overlook
Mar 23, 2011Tutor
yes it can be ...
Here when rogue was set to on users were still complaining about erratic wifi performance and drop-offs !
When rogue is on the AP scan your network continuously to find another unwanted (or not) APs. When set to off, connections work flawlessly ;)
For the 350 system log i have found why there is nothing here ! We have configured APs to use a syslog server. If i disable the syslog feature all logs are showing in the system log window ! Humm Netgear support : :mad: Netgear never told me that...
But, if you can, use a syslog server (kiwi or another soft of your choice) rather than the Ap buffer; there is no log size limit, you can archive, email, etc....
Since 1 year we have these APs all logs are archived. I have searched for "entering disabled state" keywords and i have only found that each time it was disabled state it was for technical reason and not an issue.
Try with rogue set to off and tell us if it's (better) work or not :D
