RSchwein
Mar 21, 2011Aspirant
WNDAP350's are constantly rebooting
WNDAP350 significant problems I have 5 of these on various network segments over a large geographical area. All are using different wiring, different network switches, nothing in common with any o...
RSchwein
Mar 24, 2011Aspirant
Glith wrote: Try and disable DFS on the 5Ghz radio....
I found a bug where the DFS got stuck in a loop and disabled all network traffic.
Cisco's are still working fine.
Linksys's are still working fine.
Apple Airport still working fine.
Netgear 350's still turning off their radios. For an experiment I put two 350's onto the same network segment about 100' apart with low power settings and different channels. Of course both were pinging the same router. I watched them for a while. After about an hour one had a ping failure and disconnected. But the other was doing just fine. After about a minute it came back up. A little while later the second had a ping failure and disconnected. However the first was still fine. Everything I've done seems to point conclusively to something in the 350 having problems.
I've just turned off all the 5 Ghtz radios. We'll see.
