RSchwein
Mar 21, 2011Aspirant
WNDAP350's are constantly rebooting
WNDAP350 significant problems I have 5 of these on various network segments over a large geographical area. All are using different wiring, different network switches, nothing in common with any o...
RSchwein
Mar 28, 2011Aspirant
overlook237 wrote: Faulty hardware series :confused:
To be sure call your Netgear tech support and ask for a RMA for 1 AP and test.
Now that I know where to look I've been packet capturing with a focus. Comparing what I capture with the 350's logs shows that the 350 and reality are not collocated.
When the 350 goes off line it's logs show that it is pinging and not getting a reply. However, packet capture shows that all pinging stops. Indeed, during the 350's blackout someone on the network can not ping the 350. It appears to have turned off its Ethernet port. Yet, it's log shows that it believes it is connected to the network and it continues to ping.
Firmware; Hardware? I haven't called Netgear yet; would I be the first to surface this problem?
