RSchwein
Mar 21, 2011Aspirant
WNDAP350's are constantly rebooting
WNDAP350 significant problems I have 5 of these on various network segments over a large geographical area. All are using different wiring, different network switches, nothing in common with any o...
RSchwein
Mar 28, 2011Aspirant
Glith wrote: Try to disable Auto channel if you have it set on any radio.
They are all set to Auto channel. Heck, I've pretty much disabled everything else, why not this? I'll try it.
In the mean time - below is the relevant part of the 350's log:
Mar 28 14:21:56 hostapd: Network Integrality: Ping Success
Mar 28 14:22:50 hostapd: Network Integrality: Ping Failed
Mar 28 14:22:50 hostapd: Network Integrality: Host: 10.100.255.254 is down.Bringing down all the vaps
Mar 28 14:22:50 kernel: brtrunk: port 2(wifi0vap0) entering disabled state
Mar 28 14:22:50 hostapd: wifi0vap0: STA 00:1f:f3:bd:f6:c3 IEEE 802.11: disassociated
Mar 28 14:22:50 hostapd: wifi0vap0: STA 00:16:ea:c3:44:b2 IEEE 802.11: disassociated
Mar 28 14:22:58 hostapd: Network Integrality: Ping Failed
Mar 28 14:23:01 hostapd: Network Integrality: Ping Failed
Mar 28 14:23:01 hostapd: Network Integrality: Host: 10.100.255.254 is down.Bringing down all the vaps
Mar 28 14:23:06 hostapd: Network Integrality: Ping Failed
Mar 28 14:23:09 hostapd: Network Integrality: Ping Failed
Mar 28 14:23:14 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:04 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:08 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:11 kernel: NETDEV WATCHDOG: eth0: transmit timed out
Mar 28 14:35:11 kernel: ag7100_tx_timeout
Mar 28 14:35:11 kernel: ag7100_ring_free Freeing at 0x803ec000
Mar 28 14:35:11 kernel: ag7100_ring_free Freeing at 0x86a6c000
Mar 28 14:35:11 kernel: ag7100_ring_alloc Allocated 4800 at 0x803ec000
Mar 28 14:35:11 kernel: ag7100_ring_alloc Allocated 3024 at 0x86a6c000
Mar 28 14:35:11 kernel: AG7100: cfg1 0xf cfg2 0x7215
Mar 28 14:35:11 kernel: VSC8601: Found 0 unit 0:0 phy_addr: 1 id: 004dd04e
Mar 28 14:35:11 kernel: VSC8601: PHY is an Atheros F1E
Mar 28 14:35:11 kernel: VSC8601: unit 0 phy_addr 1
Mar 28 14:35:11 kernel: Writing 4
Mar 28 14:35:11 kernel: brtrunk: port 1(eth0) entering disabled state
Mar 28 14:35:12 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:15 kernel: VSC8601: unit 0 phy_addr 1
Mar 28 14:35:15 kernel: AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
Mar 28 14:35:15 kernel: AG7100: pll reg 0x18050010: 0x11110000 AG7100: cfg_1: 0x1ff0000
Mar 28 14:35:15 kernel: AG7100: cfg_2: 0x3ff
Mar 28 14:35:15 kernel: AG7100: cfg_3: 0x18001ff
Mar 28 14:35:15 kernel: AG7100: cfg_4: 0xffff
Mar 28 14:35:15 kernel: AG7100: cfg_5: 0xfffef
Mar 28 14:35:15 kernel: AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
Mar 28 14:35:15 kernel: brtrunk: port 1(eth0) entering learning state
Mar 28 14:35:16 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:20 kernel: brtrunk: topology change detected, propagating
Mar 28 14:35:20 kernel: brtrunk: port 1(eth0) entering forwarding state
Mar 28 14:35:20 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:21 hostapd: Network Integrality: Ping Success
Mar 28 14:35:21 hostapd: Network Integrality: Host: 10.100.255.254 is UP. Bringing up all the vaps
Mar 28 14:35:21 kernel: brtrunk: port 2(wifi0vap0) entering learning state
Mar 28 14:35:25 hostapd: Network Integrality: Ping Success
Mar 28 14:35:25 hostapd: Network Integrality: Host: 10.100.255.254 is UP. Bringing up all the vaps
Mar 28 14:35:26 kernel: brtrunk: topology change detected, propagating
Mar 28 14:35:26 kernel: brtrunk: port 2(wifi0vap0) entering forwarding state
Mar 28 14:35:32 hostapd: wifi0vap0: STA 60:fb:42:6d:6d:3e IEEE 802.11: associated
Mar 28 14:35:43 hostapd: wifi0vap0: STA 00:1f:f3:bd:f6:c3 IEEE 802.11: associated
