RSchwein
Mar 21, 2011Aspirant
WNDAP350's are constantly rebooting
WNDAP350 significant problems I have 5 of these on various network segments over a large geographical area. All are using different wiring, different network switches, nothing in common with any o...
RSchwein
Mar 30, 2011Aspirant
Well, I turned off auto channeling on all of them. I set them to least congested frequencies in their areas. About 1 hour later one of them went down. Same problem. Ping failure, turn off their Ethernet port but, it still continues to ping as if it's still connected even though it's turned off it's port. About 11 minutes later some kind of watchdog kicked in, cleared everything up, it turned it's Ethernet port back on and guess what..... ping success.
About the only thing left to turn off is the device it self by unplugging it.
By the way, this is not happening on just one 350. I have five of them and they are all doing the same thing.
