SavellM
Mar 19, 2012Aspirant
WNDAP360 losing connection
So I have a WNDAP360, running the latest 2.1.1 firmware. It is setup to be as basic as possible. I have disabled the QoS features, and set the channel. I looked with inSSIDer and got my 2 most free...
X_Man
Apr 02, 2012Aspirant
I meet a similar problem
The WNDAP360 is connected to my NetGear GS108PeV2 switch.
I use the supplied power adapter for the AP.
Everything is ok but the AP is rebooting constantly (after 3 to 5 minutes) !
If I connect my laptop to the switch directly, I have no problem.
I also tried to check if the 2.1.1. firmware was completed but I did not find any place in the menu with firmware version.
I will appreciate if someone can give me a help.
Thanking you in advance
