SavellM
Mar 19, 2012Aspirant
WNDAP360 losing connection
So I have a WNDAP360, running the latest 2.1.1 firmware. It is setup to be as basic as possible. I have disabled the QoS features, and set the channel. I looked with inSSIDer and got my 2 most free...
jshelton_li
Jun 14, 2012Aspirant
I have found what appears to be a compatibility issue between Netgear's 802.11N and devices that utilize Broadcom chipsets. I have been testing in my lab and at client locations and those two similarities seem to pop up consistently across multiple Netgear APs with multiple firmwares. I made a change at a location that disables the 802.11N, changing to 802.11 b/g on the APs. I will try to post back my findings. I have also been in contact with Netgear Level 3 support and have informed them of my findings.
