SavellM
Mar 19, 2012Aspirant
WNDAP360 losing connection
So I have a WNDAP360, running the latest 2.1.1 firmware. It is setup to be as basic as possible. I have disabled the QoS features, and set the channel. I looked with inSSIDer and got my 2 most free...
jrich
Jul 20, 2012Aspirant
I have 3 WNDAP350 units doing the same thing. Apple products will for all purposes drop connection, but still showing great signal and connection to the AP. Only way to solve the problem is to manually disconnect then reconnect to AP. Have tested with a Lenovo laptop using Intel chipset and also experience the same symptom, although not as often as Apple products. Any Apple product (iphone, macbook) will lose connection after 10 minutes use or so. Anyone found a solution or is turning off N the only possibility? Could one possibly use 2.4ghz radio for just b/g then use 5ghz radio for N?
