IsLNdbOi
Nov 02, 2011Aspirant
WNDAP360 w/ external antennas?
I'm interested in purchasing a WNDAP360, but before I do I'd like to know if anyone here has answers to any of these questions. I see that the WNDAP360 has two external antenna connectors. The WND...
tquade
[QUOTE=jmizoguchi;376579]there is NOT internal antenna. if you remove you will loose the signal quite rapid.
http://www.l-com.com/home.aspx
you can see different antenna types
QUOTE]
This is not correct. The device has internal antenna for both 2.4 and 5 GHz bands. The external connectors are for optional 2.4 GHz antenna. They can be enabled under advanced wireless configuration.
Ted Quade
QUOTE]
Ted Quade
