jamster001
Dec 07, 2011Novice
WNDR 3700 Problems!
Hello. I have a Netgear WNDR3700 router. For the past year or two it has worked great. Now I continue to have problems and honestly to the point of buying a different router. First, here are my con...
jmizoguchi
Dec 08, 2011Virtuoso
1.) When I go to use my laptop, sometimes it has a wireless signal and other times it cannot connect to the internet but I can access local network. I normally unplug the modem and turn off the router, then fully power up the modem and then turn on the router. Sometimes this works and sometimes it does not.
if you have not hard reset there router, do that first and see behavior
