jamster001
Dec 07, 2011Novice
WNDR 3700 Problems!
Hello. I have a Netgear WNDR3700 router. For the past year or two it has worked great. Now I continue to have problems and honestly to the point of buying a different router. First, here are my con...
jamster001
Dec 08, 2011Novice
jmizoguchi wrote: if you have not hard reset there router, do that first and see behavior
Thank you for your reply. I did hard reset the router and I continue to have the exact same problems. Sometimes I have a wireless connection, other times I only have Local Network abilities. The PS3 will not accept the DMZ IP and even if I allow the PS3 to setup network connections using "Easy Mode", it fails to connect. The only changes I made in the configuration page are:
- Changed router login IP to 192.168.11.11
- Enabled Wireless Access Card List for laptop and iPod Touch
- Set DHCP range from 192.168.11.12 to 192.168.11.254
- Named both 2.4 and 5 GHz SSIDs to different names.
- Enabled WPA2-PSK [AES] security and entered SSID passwords for both 2.4 and 5 GHz connection.
- Enabled DMZ IP to 192.168.11.150 (for PS3 IP use)
- Set NAT Filtering to Open
- Turned on QOS Internet Access ON
- Set QOS rule for PS3 by LAN Port 1 (which the PS3 is connected to).
I am at a total lose and TBH very upset. I hope I can get this working correctly again. Again, thank you dearly for your solution attempts.
