jamster001
Dec 07, 2011Novice
WNDR 3700 Problems!
Hello. I have a Netgear WNDR3700 router. For the past year or two it has worked great. Now I continue to have problems and honestly to the point of buying a different router. First, here are my con...
jamster001
Dec 09, 2011Novice
jmizoguchi wrote: make sure you do not have channel interference issues as well
What is the recommended channel for 2.4 GHz? I have used 1, 6, and 11 with the same results. I continue to either have no internet access or it will work for a short period of time. Anything else you see wrong? Is my DHCP range acceptable with my DMZ IP and router login IP change?:confused:
