jamster001
Dec 07, 2011Novice
WNDR 3700 Problems!
Hello. I have a Netgear WNDR3700 router. For the past year or two it has worked great. Now I continue to have problems and honestly to the point of buying a different router. First, here are my con...
jmizoguchi
Dec 10, 2011Virtuoso
http://www.metageek.net/products/inssider/
you need to use tool and see what is the surrounding like.. if you live in saturated area, you may need to to explore using 5ghz instead of 2.4Ghz because of channel issues, 1,6,11 is non overlap channel and should use those only unless you are in Europe which uses unto 13 channels
