occicat
Nov 29, 2021Star
Wndr3300 as range extender not working anymore
I have a r6700 in one area I’d my house and a wndr3300 in another area. I followed the following instructions below using a Ethernet cable to connect the r6700 and wndr3300 and have the wndr3300 wifi ...
occicat
Nov 29, 2021Star
Time flies I suppose, I did not know that it has been that long.
I’ll try changing the SSID and see if that helps.
Would it be advantageous to get a second r6700 to use as a repeater and replace the wndr3300?
Also, I just saw I’m 23 devices out of 25 on the r6700. I saw the r7000 which can handle 35 devices. Not sure if I should go for the r7000 and demote my r6700 as a repeater or am I misunderstanding how attached devices are handled?
Nov 30, 2021Guru - Experienced User
It can "handle" more devices than they list. Its more about what they recommend for an "up to..." to prevent slower speeds/performance.
If it was me and I was needing a router and an access point for coverage, I'd be looking at renewed/refurbished mesh systems like the RBK43. It can usually be found for pretty reasonable renewed and would be a full mesh system with the roaming protocols. plus it supports both wired and wireless backhauls.
- occicatNov 30, 2021Star
I picked up another r6700 for cheap last night to use for now in the meantime the wndr3300 seems to have something wrong with the wifi portion after changing the SSID's and noticing poor connectivity, wired is fine however if you plug a device into the back of the wndr3300. 14 years is certainly a long time and it's done wonderfully. I really hate to put my Netgear gear out to pasture like that but it's probably time.
I'm going to take a look at the RBK43, I haven't been paying attention the the network/router game in a while so I have to familiarize myself with the new tech in the RBK43.- plemansNov 30, 2021Guru - Experienced User
good luck with it!
the R6700 is a pretty solid router.
You should have pretty good performance if you're using 1 as primary and 1 as access point.
That's the goal temporarily. I've got a r6700 currently that was the replacement for the old wndr3300 and that was relegated to being an access point that has a ethernet cable run from the r6700 to it.
So now I'm going to replace the wndr3300 with another r6700 and plug that into the base r6700 via ethernet cable and hopefully see how that works for the time being.
And then read up on the newer tech that's out there from Netgear for a future upgrade cause I have a feeling it's going to be around the corner.
