occicat
Nov 29, 2021Star
Wndr3300 as range extender not working anymore
I have a r6700 in one area I’d my house and a wndr3300 in another area. I followed the following instructions below using a Ethernet cable to connect the r6700 and wndr3300 and have the wndr3300 wifi ...
Nov 30, 2021Guru - Experienced User
good luck with it!
the R6700 is a pretty solid router.
You should have pretty good performance if you're using 1 as primary and 1 as access point.
occicat
Nov 30, 2021Star
That's the goal temporarily. I've got a r6700 currently that was the replacement for the old wndr3300 and that was relegated to being an access point that has a ethernet cable run from the r6700 to it.
So now I'm going to replace the wndr3300 with another r6700 and plug that into the base r6700 via ethernet cable and hopefully see how that works for the time being.
And then read up on the newer tech that's out there from Netgear for a future upgrade cause I have a feeling it's going to be around the corner.
