OldBob
Nov 12, 2014Luminary
wndr3300 looses mbps by half
I get 52 mbps to my modem from Cox Communications if wired direct to laptop but when I test my laptop wireless thru this dual band router wndr3300, I get only HALF mbps..I have tried every G and N ch...
fordem
Nov 12, 2014Mentor
Have you tested with a wired connection through the router?
This might/would allow you to determine if the problem is the router or the WiFi.
Also - when using WiFi, what is your connect speed?
