OldBob
Nov 12, 2014Luminary
wndr3300 looses mbps by half
I get 52 mbps to my modem from Cox Communications if wired direct to laptop but when I test my laptop wireless thru this dual band router wndr3300, I get only HALF mbps..I have tried every G and N ch...
OldBob
Nov 13, 2014Luminary
fordem wrote: Have you tested with a wired connection through the router?
This might/would allow you to determine if the problem is the router or the WiFi.
Also - when using WiFi, what is your connect speed?
I have tested direct and I get full mbps..and since my post I have changed the security of the router to AES and the Vista speed status is now 270 ..up from the 54 mbps it was and I am getting my full speed from Cox..
BUT on the W7 laptop, there is no change..and in the status section I see the ipv6 has no connection ..does that have something to do with it? Any help appreciated as I am flying way over my head but still trying.
