OldBob
Nov 12, 2014Luminary
wndr3300 looses mbps by half
I get 52 mbps to my modem from Cox Communications if wired direct to laptop but when I test my laptop wireless thru this dual band router wndr3300, I get only HALF mbps..I have tried every G and N ch...
OldBob
Nov 14, 2014Luminary
Reading on Netgear, I changed my MODE to up to 270 at 2.4 GJz and that automatically changed my 11N Channel to 3 and blocked out the options to change the 11G set to 11/2.4 GHz and I cannot change that now..The good news is that I am getting full speed on both laptops now but I am confused.
This is a dual band router..is the BAND the g/n or the GHz of 2.4 or 5 GHz? With this setting, I guess I am only used the 2.4 GHz as the light on the router for the 5 GHz is no longer lit.. So if the BAND is the GHz why am I setting it to use only one?
Can someone clarify this for me so I understand what I am doing?
