OldBob
Nov 12, 2014Luminary
wndr3300 looses mbps by half
I get 52 mbps to my modem from Cox Communications if wired direct to laptop but when I test my laptop wireless thru this dual band router wndr3300, I get only HALF mbps..I have tried every G and N ch...
OldBob
Nov 14, 2014Luminary
thank you for a most informative answer..so I guess it is a trial and error thing..I think I will leave as I have it set per the suggestions of Netgear until I see a problem.
Can you tell me how I can identify "Interferrence"..would this be if my game locks up or I loose connection or something of that sort or just slowness of connection.. Would changing the channel from the 3 to another make things better if I do see such interferrence?
