Mejet
Aug 13, 2013Novice
WNDR3400 - WPS Process Progess
I am able to connect to the internet but it will drop and reconnect periodically. I believe it is bc it changes it's channel and when it changes is when i experience the drop.
When i try to set the channel to say, 6, a popup appears that says something like, "WPS Process is in Progress, please try again later". I have tried to add a WPS and then cancel it but that does not work. When i hold down the reset button on the router for 30+ seconds it just restarts the router as if i had unplugged and plugged it back in.
Any other ideas? Thanks in advanced!
1 Reply
- jmizoguchiVirtuoso
