ianhill090776
May 22, 2011Follower
WNDR3400 can't find harddrive via USB
Hello all, I'm running... WNDR3400 + Transcend storejet 25f 500gb external hard drive + MacBook Pro running Mac OS X v. 10.6.6. The hard drive is plugged into the USB port on the Router, and I can ...
sccarlso
Oct 01, 2011Aspirant
To connect to a Windows file share on a Mac you need to use the "Connect to Server" option and put in
smb:\\readyshare
or substitute the IP of the router for the name
smb:\\192.168.1.1\
Mac's running Lion are much more friendly to Windows shares, so if you're using Lion it may just show up in your Network list.
Good luck!
smb:\\readyshare
smb:\\192.168.1.1\
Good luck!
