knightrider3001
Oct 03, 2012Aspirant
wndr3400 repeater
I have a netgear cg3000d provided by my ISP. I also have a netgear wndr3400 layin around and want to make the wndr3400 as a repeater. I have not found any configurations on the cg3000d for setup as a ...
jmizoguchi
Oct 03, 2012Virtuoso
all the post you will get will be same.... because that is the basic concept and SAME.
likely issues is your ISP provided branded firmware unit. If you could not setup with all URL with concept PDF then your branded firmware do NOT support
get wn2500rp extender and also security will be WPA2 and NOT WEP on repeating IF you could have done between CGXX and wndr3400
ALL same answer you will see. Using extender is the best way to keep wifi SAFEST
