wk55tw
Aug 02, 2013Novice
WNDR3400v1 won't connect to Internet after connecting HP B209 wirless printer
I have a WiFi network at home using Netgear WNDR3400v1 router. I have desktops, laptops, iPAD, & iPhone connected and work fine. But every time I turn on HP B209 wireless printer, anything connect to ...
jmizoguchi
Aug 02, 2013Virtuoso
wk55tw wrote: Not sure if this was caused by the firmware update I've done. But I'll check out the forum as you suggested.
If after firmware upgrade cause the issues then,
Make sure you have hard reset after you did.
I would even hard reset the router and test again. Is still the same then try to revert the firmware
Support.netgear.com and download prior firmware
