shabazosu
May 09, 2012Follower
WNDR3400v2 5GHz Issues
I purchased the N600 (WNDR3400v2) Wireless Dual Band Router last week and had no issues with the setup and getting all my devices to connect, however, I only recently discovered that only my xbox360 i...
Gregthree
May 10, 2012Aspirant
jmizoguchi wrote: Why not!
Disable built-in wifi and use USB adapter
I tried that and the PC would not connect or recognize it as a connection. I even usedthe WSP button to find it. Sould I disable the internal wi fi first. Reboot the pc and go that route.
Is there really enough advantage of doint the adapter to warrant using the adapter. I am really unclear on what I will gain by goin to the 5.0.
