Retired_Member
Jul 17, 2011WNDR3700 used as A AP
Has anyone used the latest firmware 1.0.16.98 with the AP option. I am using with a WNDR4000. Everything is fine for several hours then cannot access GUI or it times out waiting.
- Retired_MemberMore info, I am also using another another wndr4000 with auto IP checked and it is working fine. 4000 as a router to another 4000 wired as ap with auto ip.... along with a 3700 AP checked back to router the 3700 must be rebooted after several hours to view GUI and or cinnect to. When checking attached devices they both are on list.
- Retired_MemberTesting new firmware today so far it looks good. The power led is now green, it had been orange when the AP option was checked. I can access WEB_UI without any delay now and make config adjustments.
I did a factory reset, loaded firmware, selected AP mode, waited while it rebooted, powered off, connected lan port 1 to switch, waited for it show up on 4000's attached devices, reserved IP of 192.168.0.99 Used IE typed 192.168.0.99 and configured the AP.
