NGDiracDeBrogli
Oct 11, 2011Aspirant
WNDR3800 firmware bugs/mess??
Hi, The router starts off with no WLAN signals. So the 2.4GHz en 5GHz signals are off. After logging into the router (routerlogin.net in browser (IE, Opera, Mozilla) ) I then try to switch on th...
jmizoguchi
Oct 11, 2011Virtuoso
if you have NOT hard reset after flashing the firmware, do so. it may not loading the firmware correctly.
if still the same issues, revert back and again reset the router. if this fixes the issues then contact support for bug report at my.netgear.com
