NGDiracDeBrogli
Oct 11, 2011Aspirant
WNDR3800 firmware bugs/mess??
Hi, The router starts off with no WLAN signals. So the 2.4GHz en 5GHz signals are off. After logging into the router (routerlogin.net in browser (IE, Opera, Mozilla) ) I then try to switch on th...
jmizoguchi
Oct 12, 2011Virtuoso
for safety reasons I would like to disable the WPS facility in the NetGear Genie but I don't know how; I haven't found any tick-box called /Enable WPS/, or something similar.
without physical presence in front of router to initiate WPS connection so someone from outside can not use WPS to connect. There is WPS Pin disable option maybe found in the interface to refer to manual.
