shadow84
Dec 30, 2011Aspirant
WNHD3004 Wifi 802.11b/g not existing?
Dear all,
Has someone an idea if we can request netgear to get a firmware allowing to get 802.11b/g for on the super WNHD3004 Access point?
I am badly supprised I cannot connect some of my old devices only supporting this norm! (WNHD3004 only provides 802.11a/n)
Can some help me ?
Thanks very much in advance ! :D
And Happy new year to all of you! ;)
Can some help me ?
- jmizoguchiVirtuosounder 20Mhz it will do support single channel so it may work but you need to contact support with your issues.
- shadow84AspirantHi June!
Thanks for quick reply! and thanks by the way for your Troubleshooting_IKE_VPN on your site ... quite interesting for another pb that I got.
(Both of them are related to iphone 3GS connection: Wifi b/g only available and VPN IPSec connection without anything going throught...)
Do you have any experience s.o. requesting such kind of thing to Netgear support before? (with successful feedback?)
CU ;) - jmizoguchiVirtuosoiPhone are on vpn are only work with latest Prosafe and Prosecure models.
I missed actual issues you are having meaning probably you have issues with existing AP that can not work with VPN router you already have? - shadow84AspirantOups sorry Yep... I took some short cuts... I just meant that all my pb are related to my b**** old iPhone 3GS.
Yes you are right my iPhone VPN is not working with my prosafe router (FVS318G). Just wanted to say thanks for your troubleshouting post on your site.
I was just wondering if I can expect from Netgear Support or should I return my WNHD3004 and just buy a new device... Do you have any experience s.o. requesting such kind of thing to Netgear support before? - jmizoguchiVirtuosoI would go with proafe AP rather consumer eve.
wnda360 ( i maybe off on modle#) but this prosafe AP is dual band and poe with external antenna..
