Thunder7
May 11, 2008Aspirant
WNHDE111 disconnects/issues
Recently picked up the WNHDE111 kit and am having a few issues. It hooked up fine, and found each other not problem. I have been able to access the internet with nice speeds from the far bridged e...
jmizoguchi
May 11, 2008Virtuoso
Something strange I am noticing is on the AP when looking at the wireless status, it shows the IP of the bridge as one from my DHCP range (not the static address that has been assigned to it, and is used for management of the device).
WGR614 router <-> WNHDE111 AP <- WNHDE111 Bridge
192.168.1.1 192.168.1.2 192.168.1.3
ll the devices receive a DHCP address from the router in the 192.168.1.10x range.
so what is IP of this AP are getting? 192.168.1.10x I assume.
transfer from G to N wireless speed will bring you bottle neck and moving higher file size may seize the transfer.
here is the throughput of wireless you will expect.. good article
http://vpncasestudy.com/download/usefuldoc/wifi_performance.pdf
