Thunder7
May 11, 2008Aspirant
WNHDE111 disconnects/issues
Recently picked up the WNHDE111 kit and am having a few issues. It hooked up fine, and found each other not problem. I have been able to access the internet with nice speeds from the far bridged e...
Thunder7
May 14, 2008Aspirant
jmizoguchi wrote: so what is IP of this AP are getting? 192.168.1.10x I assume.
transfer from G to N wireless speed will bring you bottle neck and moving higher file size may seize the transfer.
here is the throughput of wireless you will expect.. good article
http://vpncasestudy.com/download/usefuldoc/wifi_performance.pdf
Yes, 10.168.1.103. Not sure why when the LAN IP address is set to static 10.128.1.3
Perhaps the transition from G to N is causing it lock up? Hmm....still it shouldnt do that.
The bridge is also requiring a reset everyday...even if nothing is passing through it. It will work (like now), but tomorrow if I come back I cannot get to the internet even though the lights on the bridge OK. Reset it, and it works again.
Just being a pain.
