Thunder7
May 11, 2008Aspirant
WNHDE111 disconnects/issues
Recently picked up the WNHDE111 kit and am having a few issues. It hooked up fine, and found each other not problem. I have been able to access the internet with nice speeds from the far bridged e...
Thunder7
May 21, 2008Aspirant
GLaDOS wrote: Have you tried replacing it?
Because it sounds like something else is wrong.
I am definately starting to lean toward a hardware problem with the bridge itself. Fixed the IP issue finally, so it is getting the static IP assigned, but it still disconnects within 24 hours from the AP, every single day.
I am going to be calling support this week, when i have a chance for a hour or two to spend on it. I think they may come to the conclusion that it is a hardware issue.
