Thunder7
May 11, 2008Aspirant
WNHDE111 disconnects/issues
Recently picked up the WNHDE111 kit and am having a few issues. It hooked up fine, and found each other not problem. I have been able to access the internet with nice speeds from the far bridged e...
punchbuggy
Sep 01, 2008Guide
Eqwalker, I'd appreciate if you can keep the forum up-to-date on your progress. This issue has been reported by others but not sure how they went. I have this problem also - exactly as you just described - although I admit to being lazy. I've just been living with it and powering on/off as necessary, as I'm not aware of an equivalent solution and I need it!
Good luck. IMHO this needs to be fixed in a firmware upgrade urgently - it's go to be a protocol issue.
