Thunder7
May 11, 2008Aspirant
WNHDE111 disconnects/issues
Recently picked up the WNHDE111 kit and am having a few issues. It hooked up fine, and found each other not problem. I have been able to access the internet with nice speeds from the far bridged e...
eqwalker
Sep 06, 2008Aspirant
Second level support feels that I had a hardware problem and suggested that I return them to the seller and get a replacement pair. It would appear that he was correct. The new pair so far are functioning perfectly. I installed them no differently that I did the first pair and I have streamed about 2 hours of HD on these and have not had a single failure whereas I could not get more than a few minutes on the previous pair. Now lets see if the units stay on during the night and not go offline. I will report my findings here. If they stay on then it looks like all of my problems have been solved.
