Thunder7
May 11, 2008Aspirant
WNHDE111 disconnects/issues
Recently picked up the WNHDE111 kit and am having a few issues. It hooked up fine, and found each other not problem. I have been able to access the internet with nice speeds from the far bridged e...
eqwalker
Sep 07, 2008Aspirant
I am pleased to say that the units stayed on all night and worked perfectly without any issues. So, at this point, I would suggest that anyone that is having problems like I had with my first pair to return them for an exchange or arranged to have them replaced via Netgear support. Also, if you can/do take them back to the reseller that you purchased them from, be sure you get a new sealed box unit(s). When I went back to my seller, at the exchange desk they told me to go get me a new set and come back to the exchange desk. So I went back to get a new set and found one box on the shelf that had been opened. I got the one behind that was still sealed. I didn't want to take a chance of getting a pair that someone may have bought and brought back because of the same issues. The seller may have hooked them up and seen that they worked, not knowing that they would work for a short while, and think that there was nothing wrong and put them back. Anyway, new pair here now and working good so far.
