Thunder7
May 11, 2008Aspirant
WNHDE111 disconnects/issues
Recently picked up the WNHDE111 kit and am having a few issues. It hooked up fine, and found each other not problem. I have been able to access the internet with nice speeds from the far bridged e...
indiekiduk
Feb 03, 2011Aspirant
Hey, refurbished versions of the WNHDE111 are flooding on ebay now, for the bargain price of £30. Unfortunately I suffered the same disconnections as mentioned a few years ago. It came with the original firmware, tried the update, then tried the beta, all suffer from a crash and reboot after transferring 500MB. I've tried every possible fix mentioned but those didn't solve it, however I think that by turning off WMM in the "Advanced Wireless" section it stops the crash, but at the expense of loss of 50% throughput. So by turning it off I go from about 8MB/s copying from a wired PC to 4MB/s. Btw I'm set to N only, channel 136, transmission auto (its connected at max because is right next to it), channel width 20/40, security none.
If anyone else still has theirs perhaps they could try with WMM off too?
