lk01
Jan 22, 2010Aspirant
WNHDE111 emergency recovery needed
Hello, I have a AP/Bridge WNHDE111 that is blinking once per second (corrupted firmware sign). It does not response on any buttons or network connections. Prior to becoming a paperweight, it freque...
Scottyboy
Jan 27, 2010Aspirant
From your description, sounds like hardware.
Things like bad solder joints will heat up, then open up. As they get worse, they happen more frequently. Maybe on the last boot it was reading/writing and either lost power or a memory connection which corrupted the program.
My guess would be that reloading the firmware will fix it temporarily until the next event occurs at just the right time and the program corruption will recur.
If it is still under warranty, I'd try to get a replacement.
