Lesnmatt
Dec 30, 2013Follower
WNR1000 as a base station or repeater issues
I have a WNDR 3300 that I have setup as a base station and I have tried to setup the WNR 1000 V3 as a repeater, but the repeater defaults to a unusual IP address that is well out of assigned range whe...
jmizoguchi
Dec 31, 2013Virtuoso
Just a tips , you have router products so make sure you look router section and not extender... :)
http://forum1.netgear.com/forumdisplay.php?f=31
Make sure are using WEP/54Mbps or nor security.
I would test make sure that you are overlapping the signal. Usual IP is 169 then possible you have two devices too far each other
repeater defaults to a unusual IP address that is well out of assigned range when repeater connects.
