Larry21
Jul 10, 2014Follower
WNR1000v2 upgrade question
I upgraded my speed from 20mbps to 105mbps. Do I need to call and have the new speed activated or should it have automatically changed as my tv package has already came in the mail?
1 Reply
- jmizoguchiVirtuosoYou are in wrong section
WNR1000 is a router and not WN1000RP extender
http://forum1.netgear.com/forumdisplay.php?f=32
Not sure what you mean but WNR2000 to similar can only handle 92.5Mbps so if you upgrade you will not achieve 105Mbps . If less you need to buy new router is more updates.
Any latest wireless router with gigabit will handle it
