kwsager's avatar
kwsager
wnr1000v3 problem with Filezilla
Brand-new Netgear wnr1000v3, replacing a linksys, 64bit Ubuntu (HP hardware)
the wnr1000v3 works beautifully with everything (3 hardwire ethernet PCs and 1 wireless phone) Until I try to use Filezilla...
According to the filezilla configuration wizard error message: "Some router keeps interrupting the connection." (exact words) IE - test suite for filezilla shows a series of connection protocols being completed within filezilla, shows a brief connection, and then it's gone and relays error above. I've googled everywhere for a solution. got on support with the company where I host domains.
As soon as I disconnect the Netgear and plug the old 100 mbps Linksys back in...everything works normal. I can not find any obvious configuration
Any help very deeply appreciated.
  • I apologize. I could not find any categories under forums for Netgear that seem to match. I will go back and repost somewhere under "wireless router and modem gateways." I see those are probably a better match although none of those sub-categories seem to include this product either. Again, apologies. I see that this does not belong here. Just not at all obvious where is does belong...from the layout of this forum.
  • thanks again: I reposted the question under "rangemax routers" although absolutely nothing either on the brandnew product itself nor on forums makes clear where WNR1000 questions should be posted.
